Re: Dellorto PHBN needle listing with angles
Mikey Antonakakis /
> Daniel '' Wrote:
> Depending on atomizer size the needle you need varies.
There's hardly any variance in atomizer side compared to needle size - like 0.06 or 0.08mm for the full range? Compare that to the range of needle tip diameters, which goes from like 0.6mm to 1.8mm, so a range of 1.2mm by swapping needles vs. 0.06mm by swapping atomizers. So atomizer size doesn't determine needle size...
