Re: BMW K100 Wheel swap. An in depth thread.
Nathan Wizard /
> P D Wrote:
> Is it just me or is that swing arm pretty skimpy ?
> Seems like the first bump of most any size would have that thing in
> n pretzel shape .
> The brake looks good , but , what it's mounted on ???
The swing arm has been reinforced in 4 spots so I’m hoping she holds well. Two lengths of 1/8in wall pipe as supports and two gusset plates added where it turns from tubing to the plate.
Also, In green you can see the actual mounting bracket/ spacer. You can see it keeps the wheel center and also hugs the old shock mount for added support. It’s 1/8inch steel plate I think.
The red bolts are the two end bolt holes on the bracket they secure the caliper to the bracket, and lastly the blue bolt works as a stay, keeping the bracket in that same position and locking it on tight. There is a bit welded to the back of the bracket that the blue bolt tightens into.
  BMW K100 Wheel swap. An in depth thread.Topic by: Nathan Wizard Nathan Wizard 08/14/19 08:31PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:32PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:33PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:34PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:36PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:37PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:38PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:39PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/14/19 09:14PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 09:48PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/15/19 01:30PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dirty30 Dillon Dirty30 Dillon 08/14/19 09:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/15/19 07:45AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 04:17PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 06:29PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 09:43PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:13PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: P D P D 08/16/19 09:21AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/16/19 09:34AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/17/19 12:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Alex hernandez Alex hernandez 08/17/19 09:18AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:02AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Saabsonettguy . Saabsonettguy . 08/16/19 10:08AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/16/19 01:07PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/16/19 03:05PM
