Re: BMW K100 Wheel swap. An in depth thread.
Nathan Wizard /
SPEAKING OF "OLD SHOCK MOUNTS" I converted it to a floating rear end. A long time ago that bushing was long gone and rotted. And so to avoid having my swingarm be able to move almost an entire inch side to side, I welded the fucker. I later realized this does not really let shocks work because nothing can flex. So why not reinforce whats there and take the shocks off? Some 1/8in wall tubing did the trick, and I added some gussets to areas I thought may have been weak or potential breaking points. (Shout out to my boy cj with the nice welding, and machine shop use later). Also a visual of where the caliper would sit.
This is where it got fun. My buddy CJ works in a machine shop sort of area, he modifies large trucks for a living (extending frames, adding lift gates etc.) and his boss was awesome enough to let us use the machinery and space after hours to make the caliper bracket. At first I thought this was a simple task. " Just get it to sit where it needs to, then somehow bolt it to the swing arm or that old shock mount." Then someone on here pointed out to me "what if the chain would need adjustment....?" And to that I said, "fuck".
So with a suggestion from scooter trash and a little R&D and found the normal design for most bikes was to basically make the wheel spacer into the bracket, so it moves and stays with the wheel.
motone-rear-disc-brake-caliper-relocation-bracket-p1609-3135_zoom_d6016420-c01d-4e9d-a361-74f0f39b1561_2048x.jpg
This is the one I used for a reference. Very basic and a small slot like a drum brake hub to hold it in place. I did it a little backwards and drilled a hole in the bracket and welded a nut to the back Then made a slot in the old shock mount tab so it could be bolted into place easily. But we'll get to that in a bit.
Here is the chunky spacer and washer (this combo put the wheel perfectly center when I pushed it all the way against that side). With some fun arts and crafts and I was able to make a rough, but pretty damn close rendition of what the bracket needed to look like and where the holes needed to go.
  BMW K100 Wheel swap. An in depth thread.Topic by: Nathan Wizard Nathan Wizard 08/14/19 08:31PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:32PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:33PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:34PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:36PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:37PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:38PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:39PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/14/19 09:14PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 09:48PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/15/19 01:30PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dirty30 Dillon Dirty30 Dillon 08/14/19 09:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/15/19 07:45AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 04:17PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 06:29PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 09:43PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:13PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: P D P D 08/16/19 09:21AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/16/19 09:34AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/17/19 12:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Alex hernandez Alex hernandez 08/17/19 09:18AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:02AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Saabsonettguy . Saabsonettguy . 08/16/19 10:08AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/16/19 01:07PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/16/19 03:05PM
