Re: BMW K100 Wheel swap. An in depth thread.
Nathan Wizard /
Here is the press in spacer, drilled and tapped for a tomos sprocket, and milled for the 6301 bearing. Ready to chill and then smack into the heated hub and sit flush and flat thanks to them milling the wheel out a little giving it an even shelf to sit on. SHOULD THIS EVER SLIP: I'll drill and put a setscrew in to help pinch the spacer, but this was pressed in with green "slip fit" locktite. I think moped power won't ever be enough to break this loose but I at least have the back up plan. Now you can see in previous photos behind the spacer lie the 4 counter sunk holes that will hold my rotor adapter. It's a pain that when I need to change the rotor I'll have to knock the spacer out but it's not chintzy and should come out with some heat and a good pounding from the backside by placing a rod in through the bearing on the other side.
I did indeed run into a slight road block. My wheel came with no rotor and a new one even used was upwards of 150-200 bucks. No thanks. I had a cr80 rotor laying around and they are significantly cheaper to replace. SO I had another spacer made to adapt the patter. In the last photo you can see how it all sits on the wheel.
  BMW K100 Wheel swap. An in depth thread.Topic by: Nathan Wizard Nathan Wizard 08/14/19 08:31PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:32PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:33PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:34PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:36PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:37PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:38PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:39PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/14/19 09:14PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 09:48PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/15/19 01:30PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dirty30 Dillon Dirty30 Dillon 08/14/19 09:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/15/19 07:45AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 04:17PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 06:29PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 09:43PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:13PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: P D P D 08/16/19 09:21AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/16/19 09:34AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/17/19 12:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Alex hernandez Alex hernandez 08/17/19 09:18AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:02AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Saabsonettguy . Saabsonettguy . 08/16/19 10:08AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/16/19 01:07PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/16/19 03:05PM
