Re: BMW K100 Wheel swap. An in depth thread.
Nathan Wizard /
My game plan was a simple one. have the hub milled out to press in a spacer that could hold my sprocket and a bearing. And have the other side where the ruined splines were, milled just enough to press fit another bearing, I chose 6301 (12x37x12) because the OD required the least amount of materiel to be removed from the spline area, and gave me a 12mm ID for a standard axle most mopeds would use. When I got the wheel I was ecstatic. My original plan did not include milling the open hub, just getting a spacer made to press in, so I cut out a good bit of the triangle gusset bits to make room, using a depth gauge on my micrometer to make it decently even, later on the machine shop ended up milling it out just a teeny bit anyway, to make sure it was 100% even the whole way around and the spacer would not try to sit crooked once pounded in.
This was my work cutting away some of the gusset.
I found a machine shop in my town, NYE machine. I saw their specialty was "prototype production and one off work". SUPER pleasant guys and only 60 an hour. they enjoy being the one shop willing to help the local guy with a project out.
Here are the results after the milling of both sides.
  BMW K100 Wheel swap. An in depth thread.Topic by: Nathan Wizard Nathan Wizard 08/14/19 08:31PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:32PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:33PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:34PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:36PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:37PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:38PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:39PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 08:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/14/19 09:14PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/14/19 09:48PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/15/19 01:30PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dirty30 Dillon Dirty30 Dillon 08/14/19 09:41PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/15/19 07:45AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 04:17PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 06:29PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/15/19 09:43PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Jeff Parr Jeff Parr 08/15/19 11:13PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: P D P D 08/16/19 09:21AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Charlie BUZZARD Charlie BUZZARD 08/16/19 09:34AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/17/19 12:52AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Alex hernandez Alex hernandez 08/17/19 09:18AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:02AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Saabsonettguy . Saabsonettguy . 08/16/19 10:08AM
  Re: BMW K100 Wheel swap. An in depth thread.Re: Nathan Wizard Nathan Wizard 08/16/19 01:07PM
  Re: BMW K100 Wheel swap. An in depth thread.Re: scuitar rex scuitar rex 08/16/19 03:05PM
