> Seth B Wrote:
> You should be able to do that pretty easy. Just a properly tuned 14 mm
> carb, intake, and hi flow filter will get you to 35 easy. Flip second
> gear clutch when you replace the pucks (you must replace the pucks) and
> your hill problem is solved. Put a pipe on, and you'll be hitting 45
> easy, with a stock hi-torque cylinder and head. Good luck!
Already did the pucks. Didn't swap gears. I'll try on #2. #1 is the base line bike. LOL.
