You should be able to do that pretty easy. Just a properly tuned 14 mm carb, intake, and hi flow filter will get you to 35 easy. Flip second gear clutch when you replace the pucks (you must replace the pucks) and your hill problem is solved. Put a pipe on, and you'll be hitting 45 easy, with a stock hi-torque cylinder and head. Good luck!
