> Lee Snover Wrote:
> Thanks for that! Mostly agrees with Myron's specs. Looks like they
> used the 2.12 atomizer in 78 and switched to 2.22 in 79/80.
> I have a 2.12 with the 56 jet, so I'm pretty close. I have already
> modified the exhausts. I have a 2.22 atomizer I can try. Kind of odd
> that they went to a smaller air intake pipe on the 2hp model? Mine
> has a white flex pipe, but in the end is a small black disc that
> restricts the hole to about half or 3/4s. I though that was odd, and I
> removed the black restrictor. Perhaps I need to put it back according
> to this spec?
> So last couple things to try. 1. Remove gasket (does it help much?)
> 2. Switch to 2.22 atomizer. 3. Go to 14mm intake (and carb? mine is a
> 12 currently) again does going from 12 to 14 make any significant
> difference?
> Cool that you guys have these documents!
Just put a new thinner gasket don’t run no gasket unless you get the mating surface is completely flat, clean and not one crum of dirt on mating surface ,
I think that whole page info is a waste of time but that’s me, The stock restrictive square airbox with different plugs and snorkels is ridiculous.
I run a metal mesh filter and a cheap performance pipe with 14mm intake, man you’re going to be taking days to that work and tune it but in about an hour of work I’ll be coming by you at about 5 to 6 miles faster then your completed experiment,
I’ve had ok luck using a known1.5- 2 hp stock cylinder and pipe with metal mesh filter too,
