If you had a 48 jet stock it was a 1hp and could have Restricted cylinder and restricted internal gearing as well as restricted external gears
No use running a different intake until you find all that that out, then if it’s a normal cylinder you could remove the thick head gasket if it has one/run a thinner one, run a performance pipe and filter
