Largest displacement kit for A35?
Tomas Molinari /
This might have been asked before, but what is the largest displacement you can mount on an A35 besides 70cc?
Re: Largest displacement kit for A35?
74cc with A lot more work.
Chöschi21 C.K. /
Well, depends on how much you want to do to it, there are guys running 120cc Vespa Cylinders on Sachs 505's after all. i bet you could put something around 200cc's on a Tomos if you try hard enough.
Probably Fred /
> something around 200cc's on a Tomos if you try hard enough. About 5,000 usd so why bother
Tomas Molinari /
lol fuck me.
Might as well just try fitting a different engine for higher displacement.
Lame
Charles McCusker /
but why do you need more than 70cc?
Probably Fred /
Because he’s a noob idiot !
Tomas Molinari /
Because I want the most out of the bike. Noob, idiot, or whatnot as Overpriced Parts said, though my autism tells me to just ignore him.
70cc is enough man.
Every now and then you have to ignore him. But seriously, 70cc is more than enough if you dial it in right. Anything more than 70cc and your asking for trouble if it's a daily rider. The stock A35/55 clutches will give you problems.
♣Slew Foot♣ /
Buy a 4-speed bottom end that will solve all your speed problems and you still keep a 64 - 74 CC cylinder as a backup for the 50cc that's already making you go 50 then there are the Tomos 80cc MC juniors does MC 80cc cylinders can be made to run but you better have a machine shop in a lot of time the one I seen had a rotary intake that was rigged through the stator
any 70 cc reed kit with a 4 pedal reed and 19 mm carb with 28 20 gearing and any shitty pipe you go faster than u want two
27/22 gearing and it will damn near get away from you if you're not careful
i agree a parma cdi box with old school a35 cdi pick up it rev till your ears bleed
