Re: Disc break caliper placement.
Wolf Wizard /
Hey scoot! I finished my mount tonight and it turned out awesome! Will be doing a full write up on the bk100 wheel swap soon in another thread. Whats the minimum clearance I should have between my caliper's static pad and the rotor you recon? I have the caliper pulled as far as I can, it's tightened down to my mount with now shims or spacers and i can fit my .635 and .559 feeler gauges between my rotor and pad. So I have about 1.2mm of space between the rotor and pad. Too much? I figure too much could warp the rotor or damage the pads. I can file away some of the surface where the mounting holes are so bring it out more if I need too.
  Disc break caliper placement.Topic by: Wolf Wizard Wolf Wizard 08/02/19 12:28AM
  Re: Disc break caliper placement.Re: Baron Von Moped Baron Von Moped 08/02/19 12:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:06AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:53AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/02/19 10:38AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 10:57AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 11:19AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 11:26AM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:09PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:25PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:34PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:49PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:08AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 02:50PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 02:56PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:43AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/14/19 03:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 04:48AM
  Re: Disc break caliper placement.Re: Dave & Bummerzz Dave & Bummerzz 08/14/19 09:35AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 11:03AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 08/14/19 12:22PM
  Re: Disc break caliper placement.Re: Michael Thomas Michael Thomas 09/10/19 11:58AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 09/10/19 01:02PM
  Re: Disc break caliper placement.Re: Charlie BUZZARD Charlie BUZZARD 09/11/19 09:18AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/17/19 02:15AM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:26PM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:28PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/22/19 01:49AM
