Re: Sorta-stuffed crank in AV7
Graham Motzing /
you'll be fine, the difference in primary compression isn't worth worrying about.
you could probably get away with a stock crank, they usually do pretty good on your stock ported type builds but i have seen a couple of them burn up the big end bearing on kitted builds so i like to replace them when possible.
plus with a moby its always nice to do those crank seals, since you cant get to them after the engine is put back together.
