How close is too close? Case matching E50
Drake Abrahamsson /
Just ported my E50 and I got awful close to the casing bolt holes. Is this TOO close? Been looking at the photos for an hour now and am getting quite anxious. Anything I can do to ease my troubled mind or am I in the clear? The hole on the bottom of the casing looks like it cut into the hole but it didn’t.
Re: How close is too close? Case matching E50
Use a sealant on the non-threaded shaft of the case bolts and do a leak-down test to check its pressure tight.
Jake Shaughnessy /
You will be good. Gasket sealer on that bolt for insurance.
Holy shit randy
Drake Abrahamsson /
Sweet, thanks! Put it back together and all went well (as far as I can tell). New problems of course now that it’s running but I’m gonna search around before I ask about that.
