Re: NC50 maximum RPM?
scrot rash /
U can see the stud ends, welded to a steel plate cut in a circle and drilled to fit puch mag bolt pattern.
Trimmed the NC hub around the spokes to fit into the mag center.
Welded 5 coupler nuts around the NC to bolt the rim on like a car. I shaved the heads and welded it for a smooth look. The plate is 3/16” and welded around the center too. It’s a 1978 NC50 Express with the tiny output axle. If u have the larger axle, an urban Express wheel laced up to 16” wheels and a good bicycle tire, moped tube. 20x2.0 tires, they hold about 95psi to keep from bottom out or ejection seat wooOoklunk
  NC50 maximum RPM?Topic by: Doug Kuhn Doug Kuhn 07/27/19 02:01PM
  Re: NC50 maximum RPM?Re: Daniel '' Daniel '' 07/27/19 08:26PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/27/19 09:29PM
  Re: NC50 maximum RPM?Re: live ɘvil live ɘvil 07/27/19 10:23PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/27/19 11:10PM
  Re: NC50 maximum RPM?Re: live ɘvil live ɘvil 07/27/19 11:22PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 01:01AM
  Re: NC50 maximum RPM?Re: Rebel Moby Rebel Moby 07/28/19 09:39AM
  Re: NC50 maximum RPM?Re: live ɘvil live ɘvil 07/28/19 10:53AM
  Re: NC50 maximum RPM?Re: scrot rash scrot rash 07/29/19 07:26PM
  Re: NC50 maximum RPM?Re: scrot rash scrot rash 07/30/19 12:17PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 11:01AM
  Re: NC50 maximum RPM?Re: live ɘvil live ɘvil 07/28/19 11:11AM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 11:30AM
  Re: NC50 maximum RPM?Re: Jack Rutherford Jack Rutherford 07/28/19 12:08PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 01:15PM
  Re: NC50 maximum RPM?Re: Jack Rutherford Jack Rutherford 07/28/19 05:08PM
  Re: NC50 maximum RPM?Re: Jeff Parr Jeff Parr 07/28/19 03:50PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 06:00PM
  Re: NC50 maximum RPM?Re: Jack Rutherford Jack Rutherford 07/28/19 06:26PM
  Re: NC50 maximum RPM?Re: Rebel Moby Rebel Moby 07/28/19 06:21PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 06:49PM
  Re: NC50 maximum RPM?Re: Jack Rutherford Jack Rutherford 07/28/19 06:55PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/28/19 07:21PM
  Re: NC50 maximum RPM?Re: Hunter Skiff Hunter Skiff 07/29/19 02:58PM
  Re: NC50 maximum RPM?Re: Jack Rutherford Jack Rutherford 07/29/19 05:17PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/29/19 06:51PM
  Re: NC50 maximum RPM?Re: Doug Kuhn Doug Kuhn 07/29/19 11:03PM
