Re: Derbi Variant PHBG 17,5 AD #2585
Mike Mayer /
> Graham Motzing Wrote:
> man that seems really low, are you sure its not an ignition problem?
> i usually run 19s and 21's and they jet in the 80's for a main. the au
> atomizer will open up flow so you'll run a smaller main but 65 seems
> real small.
> i dunno though, PHBGs don't make no goddamn sense. every time i build
> with one its a guess-and-check crap shoot.
Yes, 65 main jet. I also think it’s too small. But using the 42 idle jet until now, bigger then 65 main jet impossible to ride
With idle jet do you use?
Will check ignition, although moped on sidestand does not miss fire (edited)
