Vm20 on qt50 or towny
William Johnson /
Anyone running a vm20 on these bikes? What’s your jetting ?
Re: Vm20 on qt50 or towny
Yes, but my jetting is irrelevant because I live at 9k feet...
Need more information on what's done to the bike. Kitted? Exhaust?
Rob LaFreniere /
Co-incidentally, I am just about to install a vm20 on my qt and was about to post the same question.
I am 300 feet above sea level, have a uni pod air filter and a mlm peoples pipe, currently have a stock piston/cylinder but will be installing the 70cc malossi kit.
gracias
Rob,
Just a ballpark but should be around a 170-180 main jet with the kit. Id highly recommend a temp gauge to monitor cylinder head temps to dial in tune.
-Hunter
Rob LaFreniere /
Thanks Hunter. I do have a temp gauge. How about the pilot jet? Treats indicates that the carb will come with a 22.5.
The stock pilot jet is fine at 22.5
Rob LaFreniere /
Wundebar! Thanks again.
William Johnson /
I'm running a yt60 cylinder and head, boyesen dual stage reeds, mlm edm circuit pipe. vm20 has a 17.5 idle and started with a 180 main currently at a 165. I'm going to jump the idle up but the main is still too rich.
