Re: Tomos upgrade
Buddy Shirey /
It may be 14mm. I just assumed since the carb is 12mm the intake would be also or only slightly larger. if what you're saying it true then you could seen gains just from swapping to an SHA 14.14 without having to change anything else. He'd still want to swap in a larger intake if moving up to a 15.15 though.
