> Ken Roff Wrote:
> Throw the cylinder away for there is small exhaust port too, post for a
> good used 2hp one or get a small kit from treats, metal mesh filter,
> circuit pipe, gaskets, and some jets, Change 13t front sprocket to
> 16tooth too
Exhaustport should be the same as the unrestricted ones.
You can't take it out that easy, take the Cylinder off and use a Dremel to remove it, there is a Circlip around it.
