> Chöschi21 C.K. Wrote:
> > Ken Roff Wrote:
> > Throw the cylinder away for there is small exhaust port too, post for
> a
> > good used 2hp one or get a small kit from treats, metal mesh filter,
> > circuit pipe, gaskets, and some jets, Change 13t front sprocket to
> > 16tooth too
> Exhaustport should be the same as the unrestricted ones.
> it’s not at all on the 1hp open port cylinders in the USA
It’s tiny tiniest exhaust port one could ever/never want to see!
I know, I scrapped dozens of them over the years though if good I kept the Pistons cause they still will fit whatever number cylinder they’re marked for
The exhaust port on a 1hp is like a little rectangle on the inside of the cylinder
Plus 1hp has a super thick head gasket from the factory
