Re: Puch Polini (Dio) reed block and MLM matching inake ....
Probably Fred /
> Bob Selby Wrote:
> Yeah, pipe was on with original polini reed and mallossi reed kit...
I run a polini reed cage with non stock 4 pedal rubberized reeds and have great results with 19-21mm phbg carbs with my puch Polini kit.
The Dio is for big carbs I would think that would be overkill for a small carburetor but if you like it it runs good for you then that’s good
I used the Dio to run a large TM 24 which I did briefly, I just didn’t like the high jetting and horrible mpg,
I run regular estroil (derestricted) pipe and it’s pretty quiet too.
