Does anyone know of a good aftermarket exhaust that is good for improving performance for my 2017 tomos sprint?
Make sure you buy some jets so you can retune your carb after you change your pipe
I just put a MLM cali side bleed on my girls 2017 Tomos sprint and it rips. I cut out the snorkel in the air box, turned the idle mixture screw about 1 turn out and drilled the main jet up 2 sizes from stock.
