Best pipe for ported puch polini kit?
Jack Hernandez /
My kit is super fun, but it feels like there is more to be achieved with it. My current pipe is the the treats black pipe. Im running an HPI and a phgb 20mm carb. Ive ported the two outside intake windows, but not the middle. Without tearing my motor down , i was curious if there is a pipe more suitable for my kit?
Re: Best pipe for ported puch polini kit?
6p or simo.
OG Crazy Wayne /
Is it a E50 or a za50?
i'd give those crank pipes a shot, but i might be biased
Jack Hernandez /
E50
Dirty30 Dillon /
I will tell you know, your intake length is not helping you.
Most hi-revving reed kits like a short intake tract.
OG Crazy Wayne /
∆ RNTGLMAO ∆
Yeah your pipe is fine. Change that intake for some better performance.... Smaller gearing and more clutch tuning would be a good move as well.
Jack Hernandez /
Would that be why im getting reed flutter when im steady on the throttle? It flutters only when the HpI catches up with the throttle at 1/2 or 3/4. If I gas it after that, it hits full throttle with no flutter
Jack Hernandez /
Just dropped down to 16/45 gearing. I was worried I would loose top end of i went lower
EH 📣FCC of the QCB /
Throw an 18 on the front for more top end. I would order a 17 and an 18 see what you like better. Rule of thumb in one tooth in the front is like changing 3 in the back.
+1 for shorter intake.
The flutter may be cause by losing charge in your intake creating an air pocket. I have a dumb long intake “on purpose” on a bike and this happens.
