Re: Rectifier 103
OG Crazy Wayne /
LOL you actually did a little research amazing well in reality anything close to 2000uf with a minimum of 150 volts will Rock just fine the ones you found above in the Three Links any one of those will actually work.
And for your headlight just find yourself a 35 watt halogen bulb that plugs right in.
You don't really need an LED you've got enough power to push it around the LEDs for your brake lights turn signals and other little BS save the power for the headlight it's got to go somewhere and if you don't use it you're going to fry your regulator because it's trying to ground everything that's being generated
  Rectifier 103Topic by: Pavo Z Pavo Z 06/05/19 08:37AM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 09:17AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/05/19 12:08PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 12:47PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/05/19 03:19PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/05/19 03:20PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 03:51PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 04:10PM
  Re: Rectifier 103Re: P8R . P8R . 06/06/19 10:36AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 07:30AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 07:54AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 08:20AM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 08:44AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 09:46AM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 10:35AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 01:11PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 02:48PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 12:54PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 02:00PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 02:12PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/06/19 03:29PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 03:57PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/06/19 04:10PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 03:33PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 08:23PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/06/19 08:48PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/07/19 03:53AM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 04:01AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/07/19 10:15AM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 10:26AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/07/19 02:14PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 03:19PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/07/19 03:24PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 03:27PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/07/19 07:01PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 11:40PM
