Re: Rectifier 103
OG Crazy Wayne /
You need a 3-phase rectifier are three small rectifiers.
All the windings need to have the ground floated so you have two leads coming off each winding.
Each winding on the stator needs a separate rectifier if you can't find a full wave three phase rectifier.
then run it through your capacitor condenser then to your voltage regulator then connected to your battery if you're using one, if not just connected to your lights and all the other crap you can now use the frame as part of the ground circuit now that you have everything floated from the stator
I like using large condenser/ capacitor it has to have a very small resistor across its connections so it does not discharge blowing your bulbs and are killing you when it just charges in a Flash, I like using very large capacitors I usually find them enlarged sodium or metal halide lamps they will usually have the resistor soldered to them so all you have to do is connect to the blade connectors at the top for voltage Spike suppression.
The large capacitor should be connected to the leads coming off of the rectifiers before the regulator all you need to do is tie them in the current does not run to it just need to have the ground connected to one side and the hot to the other then connect the same way to the voltage regulator and everything should be good with all voltage floated. (edited)
  Rectifier 103Topic by: Pavo Z Pavo Z 06/05/19 08:37AM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 09:17AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/05/19 12:08PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 12:47PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/05/19 03:19PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/05/19 03:20PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 03:51PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/05/19 04:10PM
  Re: Rectifier 103Re: P8R . P8R . 06/06/19 10:36AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 07:30AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 07:54AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 08:20AM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 08:44AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 09:46AM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 10:35AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 01:11PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 02:48PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 12:54PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 02:00PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/06/19 02:12PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/06/19 03:29PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 03:57PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/06/19 04:10PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 03:33PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/06/19 08:23PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/06/19 08:48PM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/07/19 03:53AM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 04:01AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/07/19 10:15AM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 10:26AM
  Re: Rectifier 103Re: Pavo Z Pavo Z 06/07/19 02:14PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 03:19PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/07/19 03:24PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 03:27PM
  Re: Rectifier 103Re: Marc Friedman Marc Friedman 06/07/19 07:01PM
  Re: Rectifier 103Re: OG Crazy Wayne OG Crazy Wayne 06/07/19 11:40PM
