Ok, i understand now that i need to coonect to ends of coil to rectifier. And thank you very much for all your help and fast replies. Its much clearer now what i need to do..
But, i was thinking, is it possible to connect two coils like that to rectifier? Or it just work with one?
-i would like to power water/coolant pump with it. I have one, a Bosch pad 12v pump. Not sure how much watts it use? But its 0,1 bar, 900 liters per hour, so, maybe around 10 watts or less?
Malossi have same/similiar pump ;
Do you think that will work?
Not sure will i have any power left for light bulb..
