Re: Hobbit variator alternatives
Totally normal JBOT /
I will warn you,
It can be done, but it also can warp really really bad if you get it too hot.
Most likely you could true it up mostly in the bell and on the cheek, but in my experience it's awfully dicey at high rpm unless you have crazy good welding skills.
Its a much easier and better way to add race gears. Then when you get to the top of the range you're about as far as you could go.
  Hobbit variator alternativesTopic by: Chris Carleton Chris Carleton 06/04/19 07:02PM
  Re: Hobbit variator alternativesRe: Blake Totally a real doctor Blake Totally a real doctor 06/04/19 08:46PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 11:42AM
  Re: Hobbit variator alternativesRe: Chris Carleton Chris Carleton 06/05/19 03:17PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 03:21PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/05/19 04:07PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 08:58PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 09:50PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 10:13PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 10:37PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 02:21AM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:15PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:31PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:47PM
  Re: Hobbit variator alternativesRe: Jesse Stephenson Jesse Stephenson 06/07/19 01:37AM
