Re: Hobbit variator alternatives
Shane Rickert /
> JBOT Admin Wrote:
> You aren't thinking right.
> You can't go much higher because of the fixed cheek on the clutch bell..
> You gonna go above that?
> Can't do it
> Even if you cut the vari you can't go much higher than the bell allows.
> then not to mention probably not varoating enough in the rear pulley.
> If the front pulley goes farther than the rear it fucks up the crank and
> bearings.
> A cut TJT is about as high as you can go.
Exactly,
I had thoughts of making a custom rear pulley with more travel, so I made the biggest variator I could. using this to its full variation will require me to weld up the clutch bell and machine the edge sharp. Then make a rear pulley with more travel.
  Hobbit variator alternativesTopic by: Chris Carleton Chris Carleton 06/04/19 07:02PM
  Re: Hobbit variator alternativesRe: Blake Totally a real doctor Blake Totally a real doctor 06/04/19 08:46PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 11:42AM
  Re: Hobbit variator alternativesRe: Chris Carleton Chris Carleton 06/05/19 03:17PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 03:21PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/05/19 04:07PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 08:58PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 09:50PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 10:13PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 10:37PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 02:21AM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:15PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:31PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:47PM
  Re: Hobbit variator alternativesRe: Jesse Stephenson Jesse Stephenson 06/07/19 01:37AM
