Re: Hobbit variator alternatives
OG Crazy Wayne /
Are you referring to cutting the back side of the tjt so it will open further for the belt to sit deeper?
Not suggested if you're running a thin belt.
But you should definitely modify the rear pulley so it has more Gering range so you don't stress our break the crankshaft.
If you don't do this you're going to have to run the belt loose
  Hobbit variator alternativesTopic by: Chris Carleton Chris Carleton 06/04/19 07:02PM
  Re: Hobbit variator alternativesRe: Blake Totally a real doctor Blake Totally a real doctor 06/04/19 08:46PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 11:42AM
  Re: Hobbit variator alternativesRe: Chris Carleton Chris Carleton 06/05/19 03:17PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 03:21PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/05/19 04:07PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 08:58PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 09:50PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 10:13PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 10:37PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 02:21AM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:15PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:31PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:47PM
  Re: Hobbit variator alternativesRe: Jesse Stephenson Jesse Stephenson 06/07/19 01:37AM
