Re: Hobbit variator alternatives
Totally normal JBOT /
You aren't thinking right.
You can't go much higher because of the fixed cheek on the clutch bell.. You gonna go above that?
Can't do it
Even if you cut the vari you can't go much higher than the bell allows.
then not to mention probably not varoating enough in the rear pulley.
If the front pulley goes farther than the rear it fucks up the crank and bearings.
A cut TJT is about as high as you can go.
  Hobbit variator alternativesTopic by: Chris Carleton Chris Carleton 06/04/19 07:02PM
  Re: Hobbit variator alternativesRe: Blake Totally a real doctor Blake Totally a real doctor 06/04/19 08:46PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 11:42AM
  Re: Hobbit variator alternativesRe: Chris Carleton Chris Carleton 06/05/19 03:17PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 03:21PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/05/19 04:07PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 08:58PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 09:50PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/05/19 10:13PM
  Re: Hobbit variator alternativesRe: OG Crazy Wayne OG Crazy Wayne 06/05/19 10:37PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 02:21AM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:15PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:31PM
  Re: Hobbit variator alternativesRe: Shane Rickert Shane Rickert 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:33PM
  Re: Hobbit variator alternativesRe: Totally normal JBOT Totally normal JBOT 06/06/19 12:47PM
  Re: Hobbit variator alternativesRe: Jesse Stephenson Jesse Stephenson 06/07/19 01:37AM
