Re: Any room for improvement in this setup? E50 Magnum XK
> Ken Roff Wrote:
> I use use a belt sander 100 grit and then I finish sanding with 800 to
> 1000 grit paper for the head!
> I are use a old Dremel single speed with carbide bit that I got in 1992
> to open intake and remove some of metal on the piston skirts and sides
> of dome,
> I use a electric drill to drill a hole in the stock exhaust, I buy a
> a thick base gasket or double them up,
> I buy the cheapest timing light at Harbor freight,
> I tune the clutch with treats thick kickstart springs
> this is all so easy its not funny
> On my other magnum xk I run a two speed za50 engine with 74cc gila kit,
> 24tm carb and estroil pipe, this was not very hard either and was built
> 10 years ago and still runs great keeps up with traffic on 55 mph roads
That seems pretty slow for that set up.
