Hi all, I've got a quick question. I am switching over to the Polini PHBG intake and PHBG 19 on my AV10. I have previously ran a Malossi Carbonio reedblock which I had to modify the intake port for. I've taken some photos of the Polini PHBG intake block mounted up to my cases to show the overlap areas. What do you suggest I do here? Should I match the red areas on the cases to the intake and match the purple areas on the intake to the cases? There is also the green area on the intake block that has this bulbous protrusion and I feel like I should just leave it alone, I doubt it would even match with stock unmodified cases. I don't know if I should be grinding away at this intake block regardless. Thoughts on that? What are ya'll thoughts in general on how it looks and how it'd perform? I did the intake job like 7 years ago I know it's trash.... Thanks for your input, looking forward to getting a moped back on the road.
Mating Polini PHBG intake to AV10 cases that have already been modified
Re: Mating Polini PHBG intake to AV10 cases that have already been modified
Can't edit...but the green area I'm talking about is actually the purple circle...
as long as u have surface to seal with the gasket, i wouldnt worry about minor stuff. run it.
