> Buttcheeks BUZZARD Wrote:
> Well since nobody else is gonna ask... Why do you need that? I'm sure
> you have a reason
I'd guess that he just adjusted the chain to something near spec . Then applied the tensioner .
In my experience , a tensioner with a strong enough spring will help the adjustment last a lot longer , while lengthening the overall life of the chain .
The tensioner helps eliminate side flex and definitely slap or whip .
It also helps smooth shifts ,, so a bit less wear in the tranny .
