> Graham Motzing wrote:
> Yeah i just dealt with this, started shuddering and i couldn't find
> anything wrong... long story short I probably did another 300 or so
> miles after the shudder started and it grenaded my whole fuckin' tranny.
> The one-way clutch outer housing cracked, causing the rollers to jam.
> The shuddering you feel is the rollers being un-stuck when the second
> gear clutch catches. Basically the first and second gears are working
> against each other because the one-way clutch is stuck locked up.
> Eventually the cracks will get so bad that the rollers will just
> straight up jam solid, it will tear up or break the clutches or
> eventually put so much force into the first gear gearset that the teeth
> will break and get chewed off. Also it makes the reverse thread nut
> (center of 1-way bearing) tighten itself on insane-o tight.
> In order to get the motor apart i had to get that nut completely glowing
> red hot with an oxy torch 3 times, hitting it with an impact wrench.
> Destroying/ruining the temper on the countershaft in the process.
> Pretty much the whole transmission is gone from me ignoring the shudder!
Graham,
Are you saying that this is you first gear?
That has to have happened over a long period. My za50 shudders, the synchromesh made it better. But after seeing this today I swapped out my first gear and the shuddering is much much better, but not gone going into first.. I'm adding a really thin shim to see if it goes away completely.
