Re: puch za50 shift shudder
Overpriced Parts /
> Blaine- The artist formerly known as Plumber Crack "(OFMC)" Wrote:
> 1st gear clutch is splined and is to be fastened tight to the crankshaft
> with the big nut. 2nd gear clutch isn’t splined to the crankshaft.
Correct it’s not but it’s free moving and there’s play between two clutches
On a brand new engine you can wiggle it
You also can have shutter on output shaft if it goes in and out
