Re: puch za50 shift shudder
1st gear clutch is splined and is to be fastened tight to the crankshaft with the big nut. 2nd gear clutch isn’t splined to the crankshaft.
The shudder is most likely from the sprag clutch like graham has pointed out. Grip n slip, repeat rapidly. I’d carefully inspect every part of it closely.
