Re: puch za50 shift shudder
Graham Motzing /
having a loose nut on the end of the clutches or having too much play on the shimming on the clutch drum will also cause vibration that could be considered 'shudder' but i'm assuming when you say 'found nothing wrong' you mena that you checked all that stuff already.
the crack in the 1-way clutch is tough to find because its behind the sheet metal cover thingy and if you don't specifically pry that off and check you would never bother to open it up that far.
