Re: Puch Gila theoretical max RPM
jordan * /
I don't think it's necessarily the transfer timing. Soooo going off the numbers on the wiki Gila is 123' transfer and 178' exhaust, blowdown of 27.5.
I don't have much Gila experience so ima go off my experience with polini. Wiki numbers on polini are 114' transfer, 164' exhaust, 25 blowdown. I haven't modified my transfer timing, but I did open up the transfers at the base and ground out some of the webbing in the intake, as much as I could while preserving the boost port angle. I also cut auxiliary ports into the exhaust, without raising it. With a simonini pipe, I'm revving out over 13k. So with less transfer and exhaust timing than gila, it's still revving higher. Ik cutting those auxiliary ports did increase the blowdown even tho it didn't increase the duration.
If it's the same setup I remember you having, that monster Gila bk100, I bet there's more to be had in different pipes. Like with that 14k metra 65 ya had, what pipe and transfer or decking did ya do with that? Like you've done it before, maybe there's some direction to be had from that
Euro drag dudes rocking fat short pipes, I bet that's where it's at
  Puch Gila theoretical max RPMTopic by: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/30/19 01:09PM
  Re: Puch Gila theoretical max RPMRe: Totally normal JBOT Totally normal JBOT 05/30/19 01:42PM
  Re: Puch Gila theoretical max RPMRe: Totally normal JBOT Totally normal JBOT 05/30/19 01:44PM
  Re: Puch Gila theoretical max RPMRe: Adam Smith Adam Smith 05/30/19 02:21PM
  Re: Puch Gila theoretical max RPMRe: Chöschi21 C.K. Chöschi21 C.K. 05/30/19 02:45PM
  Re: Puch Gila theoretical max RPMRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/30/19 07:26PM
  Re: Puch Gila theoretical max RPMRe: Dirty30 Dillon Dirty30 Dillon 05/31/19 06:28AM
  Re: Puch Gila theoretical max RPMRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/31/19 09:09AM
  Re: Puch Gila theoretical max RPMRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/30/19 07:28PM
  Re: Puch Gila theoretical max RPMRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/30/19 07:46PM
  Re: Puch Gila theoretical max RPMRe: jordan * jordan * 05/30/19 08:07PM
  Re: Puch Gila theoretical max RPMRe: Daniel '' Daniel '' 05/30/19 08:20PM
  Re: Puch Gila theoretical max RPMRe: Totally normal JBOT Totally normal JBOT 05/30/19 10:42PM
  Re: Puch Gila theoretical max RPMRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/30/19 11:40PM
  Re: Puch Gila theoretical max RPMRe: Totally normal JBOT Totally normal JBOT 05/31/19 12:23AM
  Re: Puch Gila theoretical max RPMRe: Daniel '' Daniel '' 05/31/19 12:24PM
  Re: Puch Gila theoretical max RPMRe: Toledo Riot Toledo Riot 06/06/19 01:55PM
  Re: Puch Gila theoretical max RPMRe: Daniel '' Daniel '' 06/07/19 11:27AM
  Re: Puch Gila theoretical max RPMRe: Toledo Riot Toledo Riot 06/08/19 03:08PM
  Re: Puch Gila theoretical max RPMRe: Jake P Jake P 05/31/19 10:46AM
  Re: Puch Gila theoretical max RPMRe: Dirty30 Dillon Dirty30 Dillon 05/31/19 11:06AM
  Re: Puch Gila theoretical max RPMRe: Graham Motzing Graham Motzing 05/31/19 11:19AM
  Re: Puch Gila theoretical max RPMRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/31/19 12:34PM
  Re: Puch Gila theoretical max RPMRe: Probably Fred Probably Fred 05/31/19 01:51PM
  Re: Puch Gila theoretical max RPMRe: Derek Stahl Derek Stahl 05/31/19 02:28PM
  Re: Puch Gila theoretical max RPMRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/31/19 03:48PM
  Re: Puch Gila theoretical max RPMRe: not a Baron Asshole not a Baron Asshole 06/05/19 09:40AM
  Re: Puch Gila theoretical max RPMRe: will warn will warn 06/08/19 09:59PM
  Re: Puch Gila theoretical max RPMRe: will warn will warn 06/08/19 10:05PM
  Re: Puch Gila theoretical max RPMRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 06/09/19 06:31PM
