Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questions
Mary Hart /
She's having to use the kick starter at a stop sign? Something's really wrong, but it could be from a whole bunch of places.
If the jug is really scored, hey you have a doorstop. You probably had little compression as well which may have accounted for it dying.
If you want to leave it stock, you could probably get a decent jug at a decent price since so many people kit. You'll need new piston, rings, needle bearing, etc.
Let's see if Jack Rutherford or DPC Ryan can give info on the Athena.
  1983 Nu50 : Pros/Cons of adding cylinder kit and questionsTopic by: Andrew beaven Andrew beaven 05/28/19 09:22AM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Mary Hart Mary Hart 05/28/19 03:31PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Andrew beaven Andrew beaven 05/28/19 03:43PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Mary Hart Mary Hart 05/28/19 05:36PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Andrew beaven Andrew beaven 05/28/19 06:18PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Mary Hart Mary Hart 05/28/19 06:33PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Andrew beaven Andrew beaven 05/28/19 06:22PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Mary Hart Mary Hart 05/28/19 06:38PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Mike Boyd Mike Boyd 05/28/19 07:20PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Jack Rutherford Jack Rutherford 05/28/19 09:35PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Jack Rutherford Jack Rutherford 05/28/19 09:49PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Andrew beaven Andrew beaven 05/29/19 07:14AM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: alex ganz alex ganz 05/28/19 11:36PM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Andrew beaven Andrew beaven 05/29/19 07:21AM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Mary Hart Mary Hart 05/29/19 12:33AM
  Re: 1983 Nu50 : Pros/Cons of adding cylinder kit and questionsRe: Jack Rutherford Jack Rutherford 05/29/19 07:41AM
