transfer web alumaweld
wanna dremel transgers larger, cleaned and used aluminum sticks, is this how its done?
Re: transfer web alumaweld
Looks good to me if you have it built up high enough.
pat splat /
other side.
i guess if i dremel thru then more braze.
I'd fill the web up if it was me.
That stuff is super hard on your tools though, beware.
It doesnt look like you added much depth....i would fill up the web.
looks good just make sure its tinned out and not just sitting in there.
alumiweld really rocks for this kinda thing, much harder to get it to build. imo you really need an oxy/acetylene torch
Put it in the oven at 500 for awhile then it’ll be easy to torch it the rest of the way , hot enuff is 750. I scratch the surface with a dremel to scale the grease off, the shit will stick much faster.
