Re: This ain't gonna work, and I had high hopes too.
Graham Motzing /
hey i have a question, what is the red marker on the transfers on the kit for?
did you take the shitty gasket that came with the kit and trace it in red, then look at that on the cylinder and say 'holy shit this is way too big' because the gasket sticks out past the cylinder transfers by 3 mm?
make a new base gasket cut correctly to the kit, then put it on the engine, you'll see that there is like 1 mm overlap even in the tight spots. its not that far off. I jb weld the transfers just to be safe but if you left a little gasket overlap you probably could get away without it.
always love seeing people talk about how ports look without ever having run it. like you got fuckin superman lazer two stroke vision and you just know? it rips, run it. i've built 3 of these and they can do damn near 60 out of the box.
