That is nice work...., if had known the parma was so foreign to my stock cases, I would have been contacting you... I do understand that all a35 cases aren't built with the same base surface area...., but I never would have thought the darn cylinder would be un-workable without seriously reworking the stock case parameters.... No body enlightens you about that as far as could tell... I'm airsal once again ,and have no problem with it. Parmakit for a35 may be a real powerful build by what I did see , I swear though, the flat roof boost port I don't believe in ...., it grates against everything I have seen or have been taught in two stroke engine design.
Re: This ain't gonna work, and I had high hopes too.
