Re: I can't tune my Mikuni VM20 and need help
Overpriced Parts /
Remove topend and check for ring, piston and or cylinder seize damage, get rid of that pipe for it’s a 8k to12k rpm pipe so you need to jet it for that RPM and you can’t even get it to that RPM, I’d pitch restrictive air filter too,
I’m sure if you didn’t install the treats kids it’s not prepped, spaced, matched, squish nothing is probably done right on it to begin with either but If no cylinder seize damage and all looks OK then run a estroil or circuit type pipe, being a noob I’d run an easier to tune 14 mm bing carburetor probably first,
You will find the beginning set up of an easier tune carburetor and metal mesh filter and a low end pipe will give you if you great satisfaction of being able to use your bike instead of messing it constantly with a race pipe and carb and never being able to get it dialed in correctly
  I can't tune my Mikuni VM20 and need helpTopic by: Ahamd Bahrami Ahamd Bahrami 05/25/19 04:14PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Stephen Simmons Stephen Simmons 05/25/19 09:34PM
  Re: I can't tune my Mikuni VM20 and need helpRe: iskra chornia iskra chornia 05/25/19 10:22PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/25/19 10:29PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Russell Huddy Russell Huddy 05/26/19 12:26AM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/26/19 01:06PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Daniel '' Daniel '' 05/26/19 12:06PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/26/19 01:17PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Overpriced Parts Overpriced Parts 05/26/19 05:15PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/26/19 07:42PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Daniel '' Daniel '' 05/27/19 12:38PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/27/19 01:20PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Daniel '' Daniel '' 05/27/19 02:03PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/27/19 02:33PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Daniel '' Daniel '' 05/27/19 03:39PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/27/19 03:42PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/29/19 03:47PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Full Tuck Full Tuck 05/30/19 07:46AM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/30/19 04:11PM
  Re: I can't tune my Mikuni VM20 and need helpRe: D dB D dB 06/03/19 01:19PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Tri-ped Dave Tri-ped Dave 05/30/19 04:52PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 05/30/19 08:36PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Tri-ped Dave Tri-ped Dave 05/31/19 04:06PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Aaron Blair Aaron Blair 06/01/19 07:01AM
  Re: I can't tune my Mikuni VM20 and need helpRe: Ahamd Bahrami Ahamd Bahrami 06/01/19 03:07AM
  Re: I can't tune my Mikuni VM20 and need helpRe: alex ganz alex ganz 06/01/19 10:38PM
  Re: I can't tune my Mikuni VM20 and need helpRe: Bryan Colliver Bryan Colliver 06/04/19 11:44AM
