> P D Wrote:
> Carb looks like a Stage6 Carburetor MK2 Dellorto PHBG manual choke .
> Look for a spring and small 'puck' , inside :
That’s a cable actuated choke which is really a valve where cable end nub goes into
You want this one (which is a valve also)
https://www.treatland.tv/dellorto-PHBG-pull-choke-p/dellorto-phbg-pull-choke.htm
Unless you feel like hooking the cable and another lever up to your handlebars and then have to pull starter clutch lever and choke lever and possibly the throttle all at the same time while kicking
