needle bearing fit for stock e50/za50 con rod small end?
Brad William /
Just thinking. It can be done solidly and inexpensively. 10mm wrist pin from treats. SKF 10mm x 14mm x 14mm drawn-cup needle bearing, and a couple of 10mm id x 12mm od aluminum bushings to match the 10mm wrist pin to the puch piston.
Not that complicated really. I priced it all at about 25usd. May require very minor adjustments to the widths of spacers. Easily done. Has this been tried?(edited)
Re: needle bearing fit for stock e50/za50 con rod small end?
It might work.
I've thought about it.
Ended up making a custom bushing tho. It might be difficult for the needle bearing to get enough lube. Most rods have oiling holes.
But yeah, would love to see it done
Overpriced Parts /
Ya I tried something like that but then I had the crank lock up at bottom big end in crank for some za50 cranks don’t even have needle bearings in the big end it’s like a bushing also so I had more failures of stock cranks locking up at the big end then small end bushing go bad.
Best bet is to get a needle Conrod pressed in or Install and ream a new brass small end bushing back in
Jake Shaughnessy /
My friend did it with a different top end on a e50. It basically ate the small end and egg shaped it. Just spend the 80 bucks for a good crank
