Re: Porting Nicasil Cylinders and Porting Tools.
♣Slew Foot♣ /
the pantograph engraver is used to engrave everything from cups and trophies the inside of jewelry so if you set it up to do an inside Engraving all you need is a template of the port map and it will recreate it identically on the inside or you could even make it enlarge it or reduce it
