Re: Tuning SHA14
Derek Stahl /
> Ken Roff Wrote:
> full throttle Is full throttle,
> If you rich @ bottom end @ full throttle and good at top end Making
> holes or slide changes wont do nothing
Says he's OK WOT
> Those changes work at part throttle not full open throttle
> Making a hole that stays uncovered at full open throttle will make the
> mix rich and you want lean at bottom end rpm not rich you say.
Please explain how this is even possible? If fully open no slide should be exposed.
> Tune for top end rpm because you don’t want to seize
> so if rich at bottom rpm with full open throttle so be it,
Really? So be it? Something tells me your bikes are only tuned for WOT then.
> Get screen and black cap filter and retune with that setup you may get
> better results over stock airbox filter, the black cap has a good inlet
> hole size for the 14.14 carburetor most times
Normally I agree with Ken, but he's wrong here, maybe drunk but it's pretty early.
