> Derek Stahl Wrote:
> > Ken Roff Wrote:
> > full throttle Is full throttle,
> > If you rich @ bottom end @ full throttle and good at top end Making
> > holes or slide changes wont do nothing
> Says he's OK WOT
> > Those changes work at part throttle not full open throttle
> > Making a hole that stays uncovered at full open throttle will make the
> > mix rich and you want lean at bottom end rpm not rich you say.
> Please explain how this is even possible? If fully open no slide should
> be exposed.
> > Tune for top end rpm because you don’t want to seize
> > so if rich at bottom rpm with full open throttle so be it,
> Really? So be it? Something tells me your bikes are only tuned for WOT
> then.
> > Get screen and black cap filter and retune with that setup you may get
> > better results over stock airbox filter, the black cap has a good
> inlet
> > hole size for the 14.14 carburetor most times
> Normally I agree with Ken, but he's wrong here, maybe drunk but it's
> pretty early.
I don’t drink ‘ my God you don’t know nothing ! I’ve been messing with two cycle bikes for 42 years are you 40 years old?
Sha carbs suck for anything less than stock applications most times but 14.14 sha are great for puch or or Tomos bikes!
