Re: Moped cdi preformance help?!
Benjamin Hojnik /
Some scooters have limited CDIs. Most of the time, it hels to just disconnect the blue wire (or whatever wire is seperate from the connector). Thats usually the only restriction on 4 stroke.
2 strokes also have limited CVTs, exhausts and carbs. You need to check them all to make sure you get unrestricted power
