E50 falls on it's face at top speed
E50
15mm Bing #52 jet 217 atom needle at leanest
50cc treats with hi comp head
Points at .017" and 16mm before tdc
150lbs of compression
Biturbo (no laughing)
Chops look good nice and chocolate
No air leaks at all o ring on a #1 grandpa intake
Bottom end was redone seals and bearings and all that
Clutch grabs at 4200k (read by a shit tacho I got from Amazon)
Temps are low-mid 300s
Motor totally dies if I give it throttle
If I'm nice and gentle I can get hauling ass down the road and I try to push it to wot it will lose power
I thought it was 4 stroking so threw a #50 jet in it and still sucks. Took off the air filter and it still sucks.
Float is just lower than level when held upside down, really just enough not to overfill.
What am I looking for now?
Re: E50 falls on it's face at top speed
Fuel flow?
* wormdirt * /
> Thomas TPRF Wrote:
> Fuel flow?
It's pretty much just low enough not to leak. I might make it leak just to see. Flow from tank to carb is great
Probably Fred /
50 jet is just way too low you must not be timed right or something cause you should be at 70s (like 78) jet 2nd needle clip with metal mesh filter (stock air box is a no no) and 15mm intake
EH 📣FCC of the QCB /
Yep^^ 52 seems too low bud
Is it a fucking chines Clone of a bing?
If it's a Treats 15-clone you are good but jet it #76- #78 and time it like Ken is telling you...
* wormdirt * /
Timing is good to go, not done with a timing light, but done with feeler gauges and a piston stop
I thought 50 was low as hell too, but the chops look good. I put a 60 in there to troubleshoot it and is seemed to run worse. I have a ton of Jets so I'll start at 80 and walk it down. Just hoping it's a tuning problem and not something else
* wormdirt * /
Oh and it's a real bing
You need a timming light
* wormdirt * /
I have a timing light, it's pissing rain right now though so no work shall be done.
> shall be done.
What’s that rain have to do with anything?
* wormdirt * /
> > shall be done.
Garage is packed with too much shit and I have to work in the driveway
* wormdirt * /
Ok, put my shit under a tarp, set timing with timing light, now it's at 16mm which is the farthest I can rotate it. Currently drilling out the stator. I don't have any Jets bigger than 60, except for an 80. Slapped an 80 in and it barely runs but if I get her going it has throttle response for days. I'm trying to work back in head why I worked my jetting down from 60 and the best I can come up with is I was doing half assed plug chops, oh well.
Jets are ordered.
Thanks fellas
Chöschi21 C.K. /
16° Shouldn't really be the Problem, little bit more might help, but not by much,
Stop with the plug chopping. Listen to how it runs. Jet accordingly. Then chop away.
* wormdirt * /
Well I've been jetting in the mid 70s, but now it will start and idle when cold, but as soon as it warms up no idle unless I go WOT. I have a #24 slide so I poked a buddy hole through it and maybe it's a little better. Mid range and top end is fucking sweet though.
Timing / gap is on. Maybe a hotter plug with clear it up, I'm running a ngk 7 now
that kit likes timing set it to 18 put a NGK 8 or NGK 9 i would start with a 9 jet in the mid 70s
you might need to check to see if the piston is clearing the ports and what your port trimming is its been a long time but i think that kit needed 2 mils of exhaust timing to really get going
Totally normal JBOT /
52 jet is an idle jet
I'm surprised it even runs at wot with a 52, and you haven't seized
You need to cut the slide to get idle working at higher jetting
Look up bing slide mod.
* wormdirt * /
I did the the mod (3/16" hole), it helped a little.. maybe. Tonight I'm going to keep opening it up since I have another, unmolested slide.
Yeah 52 is pretty low but. Temps were pretty mild too. But then again I never got to go full brapp with it
Learning to tune kicks major ass
Don't do a hole.
Cut the bottom of the slide.
That's where it needs to be done.
* wormdirt * /
ok, so sand off the bottom of the slide? No problem.
* wormdirt * /
Nevermind, am I shaving the part on the left to look the the right?
Yes.
Then richen up the needle
It's actually to the left and right in that pic you posted. You're extending that circular depression in the center down on either side, hard to see in the pic but it's there
* wormdirt * /
This part?
Correct
* wormdirt * /
Slide mod didn't help. So I put a 1/4" buddy hole in the slide just to see. Still doesn't want to idle after a minute. Rechecked float height. I'm going to go back to basics this weekend and put a new gasket kit/ ring (gapped) fresh plug, rebuild the carb just go full retard with it
