Re: Stock appearing pipe
Monti S /
euro ebay has replacement hobbit/camino pipes that look exactly like stock except they are completely derestricted inside and they dont have the little tabs to mount the original heat shields. they are good to almost 40mph and not too much louder than stock.
You can also derestrict a stock PA50-II for up almost 40 by cooking all the carbon out and using a long drill bit to go through the cleaning port and punching a couple/few holes into the divider panel between the internal chambers
